I am trying to understand how to use the Align option. I have two designs made up of many objects. I would like both designs to be aligned to the bottom-most feature of the other (which I believe can be done suing 'Vertical alignment bottom'). I read the manual and think that I am not making primary/secondary selection right. How do you make primary/secondary selections?
Also on a separate topic, is it possible to move a selection of objects using coordinates? I want to move an entire design to the (0,0) starting location. The only option I found was the Move By function which only lets you enter displacement values. I guess I am looking for a 'Move To' function, if it exists?
Thanks for your help!
Tony
Hi Toni,
Apparently there is a solution already :-)
Thank you anyway for the "move to" suggestion. So far I did not consider that use case.
