But the reason is the same as there is no DCell, no DLayout etc. Region is only conceptually a collection of Polygons - internally it stores them as Shapes or even Layouts with DBU units. So a DRegion would be the same as a Region while a DPolygon for example is really something different than Polygon - it can store floating-point coordinates.
Region could accept and deliver DPolygon if it had a DBU attribute - converting them into integer objects before it stores them. That is basically a small step, but it's simply not done yet.
A convenient way to emulate that is to use a transformation:
to_um = pya.CplxTrans(dbu)
from_um = to_um.inverted()
region = pya.Region()
dpolygon = pya.DPolygon(...)
region.insert(from_um * dpolygon)
for polygon in region.each():
dpolygon = to_um * polygon
Good question
Ok, thanks for the info!
