Is there a way to copy and paste a cell without creating a new hierarchy ?
I want 2 cells almost identical, but with a small difference of connection at the top.
I want their hierarchy to be the same in case of changes in the hierarchy underneath.
Thanks, Rgds,
OkGuy
Hi OkGuy,
what you need is a "shallow copy" of cells. Such a copy is not available for whole cells yet, but you can emulate it:
You should now have a copy of the original cell using the content of the original cell but sharing their child cells.
There is another way to achieve this using the "Make Variants" function:
The latter method may be feasible if the first method is not applicable (i.e. because of insufficient space on the clipboard).
They gave me the idea of a third method :
. Create a new cell
. Instantiate the cell to copy inside this new cell
. Place it at the position 0,0 with 0 angle
. Flatten only the first level
Rgds,
OkGuy
Hallo,
You're right. That's a valid method as well. Pick the one you like best :-)
