Hi there,
I've updated to the latest version on CentOS7 and found a minor bug.
The bug is that if I set the "Style" width to 3px for any layer, KLayout will crash.
I am using 3x oversampling btw - maybe that has something to so with it...
Hmm ... I have difficulties reproducing the problem. It does not crash, neither with oversampling nor without.
Any command I could use to create some sort of "dump file" or something that could help?
@simon_ch If the problem is triggered by application code, the application intercepts the signal and shows a stack trace like this:
This information would be useful already.
Not seeing that window usually means that something goes wrong in a kernel module (e.g. graphics driver).
There is little one can do in that case. You can try running KLayout in a debugger (e.g. gdb) and see if any system error triggers (abort, segfault etc.). In that case, the stack trace again will be useful. gdb can be used like this:
Also, valgrind is a memory checker that helps identifying memory corruption issues. Run valgrind with
You will get spammed with errors from Python and Ruby, but only the last reported errors matter. However, under valgrind control, applications run abou 50x slower.
Update: I tried on a CentOS7 Docker image using my RPM from the download page.
It looks kind of ugly on a 4k screen (Qt4 does not support high-density displays), but I can't see a crash.
