Xsection bug - grow function does not work correctly
I'm trying to use xsection to build a crossing section of an SOI platform. In the previous code, grow function has been working fine. But when building the metal layer part, I want to grow an insulating layer with a thickness of 0.8um on the m1 layer, but the resulting layer result was only 0.08um, and when I changed the thickness value, the result did not change. I want to ask where the problem is? Is there any solution?
  • Hi Riox,
    If the structure always terminated/clipped at specific height, then you might need to call height(h) function at the beginning to adjust max ceiling height.
    • default ceiling height is 2um
  • Hi RawrRanger,
    Thanks very much. I forgot the limit.
