LayoutToNetlist export question
Can the connectivity built within a l2n using 'make_layer' and 'connectivity' be exported as a Technology so it can be used in 'Trace Net'?
  • Hello @mtnhomecad,
    No, actually it is the other way round. "Trace Net" in "All Nets" mode will use l2n to trace the nets.
    If you refer to single net tracing: that is a different algorithm and it only offers limited support for generated layers. L2N always operates on all nets. If you display the results in a netlist browser, you essentially will get the same functionality than "Trace All Nets".
    Is this answering your question?
  • Yes, that answers my question
    I actually updated my code so as it generates the l2n connectivity it writes a .lyt file that can be loaded afterwords.
    Thanks...
