It would be nice to be able to see additional object properties for the following cases:
Since I just started Ruby scripting, I am not sure if I could potentially extend the Object Properties window?
Hi friendx,
The properties dialog is intended to edit the object's properties, so derived properties are not shown. The rectangle origin is available however - if you use the "Corners" tab, you can edit the corner coordinates instead of the center and dimensions.
You cannot (easily) modify the object properties dialog with Ruby, but you can code an alternative one.
Create a macro with the code to compute some derived properties and bind this macro to your favourite key. A starting point for the computation may is this (the code is taken from calc_area.rbm in the "Useful Ruby modules" page):
