I am trying to write a phython script that will draw a path or polygon around the outline of a previously drawn polygon, such as the green outline in the example below. How should do this? What functions are useful? Thanks
This is straightforward and a little playing around will help you learn.
Crudely:
regA = pya.Region(pya.Box(-1, -1, 1, 1))
regB = pya.Region(pya.Box(0.5, 0.5, 3, 3))
path_outside = (regA.sized(0.1)+regB.sized(0.1)).merged()
path = path_outside - regA - regB
My idea is the same as that of mjcich. But I tried to implement it with
The KLayout Python Module.My suggestion was to use DRC which is slightly more compact:
drawn = input(1, 0) # substitute drawing layer
path = drawn.sized(100.nm) - drawn # substitute width
path.output(2, 0) # substitute output layer
However, this solution creates a path around all features on the layer.
