Error Downloading the Packages on K-Layout
I'm facing the following errors shown below when I tried installing the package on K Layout. Does anyone also facing the same issue. Please help me resolve the issue.
  • edited October 2024
    I just confirmed everything is working fine currently. The error does not indicate a particular issue.
    What is your KLayout version and OS? Is the problem reproducible?
  • I am currently using 0.29.6 version but have tried downloading the packages with other versions. The issue remains even if I change the versions.
  • Hi @Bigb,
    That is difficult to debug then. There is no obvious issue.
    Maybe your organization has firewall rules in place which do not allow access to external servers? The first level of access is plain https, but in the next level - when downloading the package - the git protocol may be required.
    When exactly do you see the error popping up?
