In a technology in the technology manager, is it possible to use a relative path for the Layer Properties file? That seems what the Base path in the 'General' tab is for? However, when I set that base path and then strip the path from the layer properties file, KLayout doesn't apply layer settings to a GDS when clicking the T-button. If I use the full path, it works.
Hallo,
the base path was intended for other components, but you're right it could be applied to layer properties as well. I'd even consider that a bug.
Right now, you have to specify the absolute path, but I will fix that in the next minor release.
Thanks for the hint,
