PATH ON OPEN FILE MENU'
Hi to All,
how can add the path where I have gds file, on "OPEN FILE" menu'?
I'm using version 0.29.0.
In attach You can see the menu on version 0.25 and in version 0.29.0
How ca I do the same on version 0.29.0??
Many thanks,
Lucky
  • This is a feature of the system file dialog. It's not a KLayout feature. Your Window manager provides this dialog and there should be some documentation somewhere.
    On the GNOME desktop that comes with my Ubuntu 24 I can pick "Add to bookmarks" from the folder view context menu in the file browser to add the item to the left-side panel.
  • I executed this command line:
    cd mypath ; klayout
    and I expected that the menu OPEN FILE select directly "mypath".
    Are You sure that the issue is in my system file dialog?
  • At least on my Ubuntu 24 GNOME the file dialog opens in the current directory as expected.
    On Windows for example, the file browser has some smartness built in to remember recent places, but that is not something I can change.
  • edited October 2024
    I have tried with version 0.25 on RH8, and the OPEN menu select directly "mypath".
    The version 0.29.0 on RH8 doesn't work in the same way.
    I used the same server RH8 with both version.
    With our IT team, We think that there is some setting into the installation of the version 0.29.0 !
    Have You any suggestion?
  • No, I have not.
    I think those are builds you did yourself as I don't provide RH8 images. So please approach the guys who supply the builds. Maybe they built against a different Qt version or a different gtk version or whatever. I cannot debug something I can't see and I don't want to.
