Meaning of a trailing "@" in the layer name?
edited November 2024 in Python scripting
What is the meaning of a trailing "@" in the layer name, for instance @ 1 in 1/0 @ 1? This appeared after I ran some Python code in the Macro Development environment, trying to visualize a created shape directly. From then on, even when I create a new layout/layer using the GUI, always the @ number appears after the layer name (layer number/datatype). How can I go back to "normal" (especially if the change can cause unwanted effects leading to harm or confusion)?
  • Hello,
    This is supposed to be the layout index: when you open more than one layout in the same panel, the layers of layout 1 have a "@1" added, the layers of layout 2 a "@2" etc... (It's not the layer name, it's the layer_number/datatype_number@layout_number...)
  • Hi Tomas,
    Thanks for sharing your insight. I currently see 1/0 @ 1, 1/0 @ 2, and 1/0 @ 5 in my KLayout window. My understanding based on your response is that these hence refer to layer 1 in different layouts (1, 2, and 5). Is this understanding correct?
    If I want to have these three patterns all in the same layout, I should therefore see something like 1/0 @ 1, 2/0 @ 1, 3/0 @ 1 (i.e., layers 1-3 in layout 1), right?
    Hunter
  • Hello Hunter,
    Indeed, that's it. In the screenshot below I opened the same file 3 times in the same panel... You can see the 3 cell structures on the left. I don't get why you have @5 instead of @3... If you have 3 layers in 1 design in the panel you typically don't see the "@1", unless it is set like that in the setup.
    It could be that the "Always show layout index in layer source" box in the Setup got selected via your script...
  • Hi Tomas,
    Thank you. That makes sense, and I was able to removed the "@" sign following your screenshot. The reason for seeing 5 instead of 3 is that I removed/closed some of the open views.
    Hunter
