I have several PCells with the same shape (or the same outer dimensions, e.g., circles and rings of the same outer radii) and need to choose one of them (different ones) to change some parameters in my layout. These PCells are typically in different layers. How can I choose the desired shape?
Solution, thanks to @srooks10:
Instead of clicking to open the Instance Properties window, one can use the keyboard shortcut "q". That works well in combination with the space bar to switch between selected objects.
