Run a polygon Convex decomposition from DRC
Good evening,
I am looking into runa Polygon Decomposition into Convex polygons from a DRC script.
Is this possible, or should I just make a lym script?
  • As so often, after I asked I found more and more similar questions, and I found an answer. I post it here, perhaps there are ways to make it faster, or somebody else wonders the same.
    The solution is to extend the DRCLayer Class inside the DRC file.
        class DRC::DRCLayer
          def decompose_convex()
            res = []
            self.data.each do |p|
              res.concat p.decompose_convex()
            return DRC::DRCLayer::new(@engine, RBA::Region::new(res))
        polys = polygons("INPUT_LAYER")
        polys.decompose_convex().output(1001)
  • Ok, and I came across a bug report, the way to go is probably like this:
    polys.data = polys.data.decompose_trapezoids_to_region
    polys.output(1001)
    Not sure why this works, but it does the same thing without making the class.
  • edited January 18
    Hi @gyger,
    the first version is actually the better one IMHO as it blends nicely into the DRC scheme. But it is not efficient as it uses a loop over the polygons. The second version is faster, but does a "decompose_trapezoids" which is not exactly the same thing as "decompose_convex" - but delivers convex polygons.
    If that is good enough, you can combine both approaches:
    class DRC::DRCLayer
        return DRC::DRCLayer::new(@engine, self.data.decompose_trapezoids_to_region)
    polys.decompose_convex.output(1001)
    "Region" has a "decompose_convex_to_region" too, so you could write:
    class DRC::DRCLayer
        return DRC::DRCLayer::new(@engine, self.data.decompose_convex_to_region)
    The difference is this:
    decompose_convex
    The decomposition into trapezoids generates minimal convex shapes (quadrangles or triangles) while the convex decomposition generates larger ones, but not necessarily the minimum number.
  • Thank you so much for responding, and for making this software happen.
