Hi ,
I'm trying to install the klayout-0.22.5] on RHEL 5 .
When I run ./build.sh I got this output :
# ./build.sh
./build.sh: line 67: ruby1.9: command not found
./build.sh: line 68: ruby1.8: command not found
Found ruby interpreter: ruby
Ruby libray found: /usr/lib64/libruby-static.a
Ruby headers found: /usr/lib64/ruby/1.8/x86_64-linux
Qt installation directory is /usr/lib (lib), /usr/bin (tools) and /usr/lib64/qt4/include (includes)
Ruby installation directory is /usr/lib64/libruby-static.a (lib), /usr/lib64/ruby/1.8/x86_64-linux (includes) and not-used (config for 1.9.x)
Platform is linux-64-gcc-release
*** ERROR: unable to locate Qt MOC in /usr/bin
How to resolve the error issue ?
/Vlad .
Hi Vlad,
You should check whether you have the Qt development tools installed. Apparently there are only libraries present on your system. You'll probably need some package like "qt-devel".
If you already have installed the Qt tools on a different location, you can use the "-qtbin" option of the build script to point it to the right location. You might also need to ser "-qtinc" to specify the path to the Qt headers in that case.
Do I need to install the qt-devel.x86_64 as well .It's headers path refers to /usr/lib64/qt-3.3 path .
/Vlad.
Hi Vlad,
is the last sentence a question? If it is, the answer is no, because Qt3 headers are not required.
