Hi, Matthias,
The function of text dump to file is a convenient tool
If it is possible to insert the text on batch mode with klayout?
For example, user prepares text file of the texts and corresponding coordinates as following,
#contents,x,y
A,0.00,0.00
A,5.00,10.00
A,4603,4135
A,4603,4137
A,4603,4139
A,4603,4142
Then use the batch command insert these texts into the layout file
Canny
Hi Canny,
that is basically easy. Here's the script core:
It's lacking user interface and you have to edit file name and target layer, but you can simply put it into a macro in the macro IDE and run it inside the editor.
It works very well and save lots of effort to give texts on gds file.
Thank you.
Canny
