I would like to know how to search for and then copy a specified cell within an open GDS file to a different blank layout using Ruby. I hope this question is not too vague.
there is no one-line copy method for KLayout yet. One user found, that you can use the clip method for that purpose, if you specify a clip box larger than the cell's bounding box. A single-line copy method is on my TODO list yet.
In general case, copying layout from one layout to another involves layer and property mapping.
new_top = ly.add_cell("ROTATED") # "new_top" is newly created cell's name or its "cell index"
ly.cell(new_top).insert(RBA::CellInstArray::new(cell_index,RBA::CplxTrans::new(1,0,false,RBA::DPoint::new(0,0))))
# select the top cell in the view, set up the view's layer list and
# fit the viewport to the extensions of our layout
layout_view.select_cell(new_top, 0)
layout_view.zoom_fit
Inside the script you basically create two layouts: one per "new" and another with "mw.create_layout". The second is empty and "new_top" is only valid in the context of the first one. I guess that is why the program crashes (it shouldn't I admit - but I did no handle every case of invalid values).
This code should be more like what you want to:
# This already creates a layout!
ly = mw.create_layout(0).layout
layout_view = mw.current_view
ly.read("LABELS.gds")
# NOTE: this should check if the cell is really there ...
cell_index = ly.cell_by_name("LABEL_A")
ly.flatten(new_top, -1, true)
(lacking "LABELS.gds" I have not tested it myself)
This should be a very simple question. How do I get the index number for a string?
For example, if a = "ABC" what function can I perform on the variable a in order to determine the number of individual string characters which in this case is three.
Hi Jared,
There has been a discussion about that topic some time ago: http://klayout.de/forum/comments.php?DiscussionID=103
Maybe that is helpful.
Can you tell me why this script keeps crashing KLayout?
module MyMacro
include RBA
ly = RBA::Layout::new
layout = mw.create_layout(0).layout
cell = layout.cell(new_top)
Hi Jared,
Hi Jared,
Do you mean the length of the string?
That is
Or do you mean the number of distinct characters?
That is
