Based on the documentation
https://www.klayout.de/doc-qt5/code/class_CellView.html#h2-138
[const] string cell_name Gets the name of the target cell currently addressed
[const] string filename Gets filename associated with the layout behind the cellview
pya.LayoutView().current().active_cellview().cell_name -> "test"
expected
pya.LayoutView().current().active_cellview().filename -> <built-in method filename of CellView object at 0x7f2ff9f280d0>
not what I expected !
both are '[const] string' should both return a string ?
However
pya.CellView().active().filename() -> test.GDS
does what I was expecting from
feature, bugs or missing something ?
Documentation problem, filename is not a string anymore
Originally I did not tried this
pya.LayoutView().current().active_cellview().filename()it works.
