Hi, Matthias,
I gds files whihc top cell are all 10 um x 10 um and cell original points are at left down corner.
The vias(0/0) with size 0.04 um x 0.04 um are randomly on whole top cell.
I want to delete the contacnt out of region 1st corner (4,4) and second corner(6,6).
If it is possible do it with rba code?
Thank you.
Canny
Hi Canny,
Here's a sketch:
Please note that this will work only in editor mode. In viewer mode, it is not allowed to erase a shape while iterating them.
I tried the above sketch, but I can't make it work.
I have 2 questions,
1. how do you get the layer index?
I wrote the command as l=RBA::LayerInfo.new(0,0)
Is it correct?
2. I still use klayout 0.21.19, when I execute the rba script, the system always feedback
Ruby error: 'undefined method `shapes' for 70:Fixnum' (NoMethodError)
The following is the script I tried, thank you.
layout = RBA::Layout.new
layout.read("test.gds")
lay=RBA::LayerInfo.new(0,0)
c=layout.cell_by_name("CLIPPED_test")
shape = c.shapes(lay)
region1 = RBA::Box::new(3908.645, 1169.02, 3912.125, 1173.75)
shape.each_touching(region1) do |s|
shape.erase(s)
layout.write("test_novia.gds")
Canny
Hi Canny,
Version 0.21.19 is quite old. But that is not the reason for the error message. In "cell_by_name" will give you the cell index, not the cell object. To get the cell object from the index, you'll have to use "layout.cell(cell_index)".
You can get the layer index by searching for the requested layer in the list of present layers. This is done like this:
