Hello Matthias,
My question is what is the proper way to configure the "read" function in KLayout so that I can read in a text file and translate it into a form that KLayout can understand and execute.
For example:
include RBA
def self.rectangle_builder(leftx,bottomy,rightx,topy,cell,layer)
cell.shapes(layer).insert(RBA::Box::new(leftx,bottomy,rightx,topy))
layout = mw.create_layout(0).layout
layout_view = mw.current_view
layout.dbu = 0.001
main_cell_index = layout.add_cell("Cell")
main_cell = layout.cell(main_cell_index)
layer = layout.insert_layer(RBA::LayerInfo::new(151,35))
rectangle_builder(-10000,-20000,30000,40000,main_cell,layer)
layout_view.select_cell(main_cell_index, 0)
layout_view.zoom_fit
How do I read in a text file through KLayout that has all of the code from the "layout.dbu = 0.001" line down and execute this translated text file with a "read("call_method.txt")" type function?
Thank you for your time.
Jared
Hi Jared,
do you mean "load"?
Ruby can execute a file in a specific place simply by writing
load("code.txt")
A more "Ruby" way is to create an object as the context for a script and use instance_eval on that object to execute the code in the context of that object.
I guess your question is about something that's called a "domain specific language". Building DSL's is a particular strength of Ruby. There are some nice articles about that topic, i.e http://jroller.com/rolsen/entry/building_a_dsl_in_ruby. This particular article is quite generic and I adopted that idea for the layer processing framework. If you plan something in that direction, considering these thoughts might be a good idea.
