Thanks for great Klayout. It give us much help.
We could use Verify->XOR in GUI, loading two layouts, setup tilts, 8 threading and output to other layout. It works very well.
Now, could we use any script to do it? We have some layouts need to verify XOR and script could give us much help.
Could you show us an example? Or point us the reference documents ?
Thanks for your great klayout again.
Dion
Hi Dion,
I am sorry, but right now the full functionality of the XOR tool is not available through the scripting interface.
It can be emulated by the layer processing framework for example, but without the multi-threading and tiling feature.
It's on my schedule, but for the next major release earliest.
Matthias had provided the layer_process.rbm macro file. You can detach it and follow his comment to use klayout -rm layer_process.rbm on the tools menu bar.
http://www.klayout.de/useful_scripts.html
Here is two layers xor example. You can detach and save as xor.rbm. Then, the xor will be shown on the menu bar tools/processing script/xor.
##-- script start ------
layer_1 = "1/0"
layer_2 = "2/0"
result = "3/0"
A = input(layer_1)
B = input(layer_2)
C = A.xor(B)
C.output(result)
##---- script end ------
Although Matthias did not recommend to use the older ruby script on version 0.22 or late, yet I still like to write the script via simple editor evinroment.
Sincerely,
arided
Hi Arided,
thanks for mentioning this. The script should work on older versions like 0.21 as well, but I'd recommend using a recent version for better performance and higher stability.
Sorry to dig out a old post (but as Matthias is mentionning it in his plan...) is there any update on using XOR tool via scripting?
Seb
Hi Seb,
The "layer processing framework" has turned into the DRC feature. XOR can be done as part of this functionality now.
Here is a sample:
If you want the layers to be derived automatically, you can use this code:
Thank you very much for your answer. I'm sorry to still have some (basic) questions on the XOR usage...
As I want to run the script in command line (something like "klayout -b -r xor.rb -rd gds1=test1.gds -rd gds2=test2.gds" that output a xor.gds) I've starting to modify your example like this:
layout = RBA::Layout::new
layout.read($gds1)
layout2 = RBA::Layout::new
layout2.read($gds2)
# Just to check that both gds are loaded
printf("Top cell name....: %s\n", layout.top_cell.name)
printf("Top cell name....: %s\n", layout2.top_cell.name)
layers = []
[ layout, layout2 ].each do |layout|
layout.layer_indices.each do |index|
info = layout.get_info(index)
layers << [info.layer, info.datatype ]
printf("Layers indices : %s\n", layers.sort.uniq )
#report("XOR")
layers.sort.uniq.each do |l,d|
(layout.input(l, d) ^ layout2.input(l, d)).output("XOR #{l}/#{d}")
I guess that the way I load the gds is not correct because I have a complain on the report method (undefined), and if I comment it (just to go on) I have a complain on input method not defined...
So If you can give me some tips or point me to the documentation on this feature I would be grateful :op
Seb
Edit: Sorry can't figure out how to format quoted piece of code :o/
Hi seb,
the forum uses "Markdown" markup. You can format code by adding four blanks before every line you want to quote.
Regarding you code, you need to be careful not to mix two concepts: DRC scripts and Ruby scripts.
If you want to run a DRC script standalone you need to save it with the suffix ".drc" and run it in KLayout like
klayout -b -r xor.drc ...
.Your script is a mixture between both slangs. Basically this is possible because DRC scripts are built atop of usual Ruby scripts. However, DRC scripts use their own methods and objects which are build atop of RBA objects.
You can see the difference for example here:
In fact, in DRC scripts, the "Layout" object is a DRC-specific layout object which - along with a
RBA::Layout
- carries additional information the DRC engine requires. But you can access theRBA::Layout
object inside a DRC layout object with thelayout
method as seen in the second example above.Given that, the DRC code for the standalone XOR looks like this:
Thanks a lot, this is exactly what I was trying to do.
Now it's more clear about DRC / Ruby script difference, should be useful for a next script.
Seb
