I just started working with klayout recently and I would like to write a pcell(for a coplanar waveguide). The round_path pcell from the basic library would be an ideal starting point for this. Unfortunately I can't find the code for it anywhere. It's not in my ~/.klayout/libraries folder. Is it not available or am I just missing something?
Alex
Hi Alex,
the round path PCell is not coded in Ruby but in C++ to support installations without Ruby interpreter. It's possible to create PCell's in C++ as well but I don't like to advertise that API. It's somethat different and not as easy to use as the Ruby API.
For your purpose I think the circle sample PCell is best starting point.
Matthias,
I have same question as Alex. However to follow-on: That's fine if it happens to be coded in C++ instead of Ruby. However I still have the same problem as Alex -- I can't find the C++ version (note that I just want to use it as-is, not change it). Where do I find it (and all the other Pcells in Basic Library)?
David
Hi David,
you can find the C++ PCell code in the "libBasic*" files. Each PCell has a .h and .cc file and the name corresponds to the PCell. But as I mentioned, I currently don't advertise this method of creating PCell's, because I don't want to spend the effort of additionally supporting the internal C++ database API (which is somewhat different from the Ruby API).
Aha! For useful reference of anyone else reading this, as for the use of the Pcell itself, to find it you go Instance > Instance tab > Library: Basic, then click "..." button and choose ROUND_PATH. Somehow I didn't find this before.
And as you pointed out it's of course included in the latest development code base (here, for future reference: http://klayout.de/build.html#all_downloads). I only installed the Windows binaries previously and hence never downloaded this and thus couldn't find this either. So now I have everything I need.
Thanks Matthias,
David
