How to erase polygons from each other
edited August 2013 in General
In the menu are the options "add", "merge", "erase", "mask" and "diff" for polygons.
For "merge" I use:
edge = EdgeProcessor.new
edge.simple_merge_p2p([polygon_1, polygon_2], false, false, 1)
For "diff" I use:
edge.simple_merge_p2p([polygon_1, polygon_2], false, false, 0)
For "mask" I use:
edge.simple_merge_p2p([polygon_1, polygon_2], false, false, 2)
I couldn't figure out how I can get "erase" to work. Is it possible with the same "simple_merge_p2p" or something completely different?
Stefan
  • edited November -1
    Not sure if this is what you want but there is an erase method in Shapes. http://klayout.de/doc/code/class_Shapes.html
    So you could do
    module EraseSelectedShape
      mw = app.main_window
      lv = mw.current_view
      if lv == nil
        raise "No view selected"
      lv.transaction("Erase selected shape")
      begin
          obj.shape.shapes.erase(obj.shape)
        ensure
        lv.commit
    Hallo,
    "erase" in the menu is basically a boolean "not", "mask" is "and" and "diff" is "xor".
    Is that comment helpful?
    Here's one more comment:
    The boolean operations are available with EdgeProcessor#boolean_p2p:
    # "not" aka "erase":
    edge.boolean_p2p([ polygon_1 ], [ polygon_2 ], EdgeProcessor::ModeANotB, false, false)
    # "xor" aka "diff":
    edge.boolean_p2p([ polygon_1 ], [ polygon_2 ], EdgeProcessor::ModeXor, false, false)
    # "and" aka "mask":
    edge.boolean_p2p([ polygon_1 ], [ polygon_2 ], EdgeProcessor::ModeAnd, false, false)
    It's worth a note that using the boolean operations has some advantages over "simple_merge". The boolean operations will normalize self-overlapping regions of the original polygons automatically for example.
