This question is more about the user interface, and not so much about KLayout's features.
When I have several windows open, I find it a little difficult to tell them apart at a glance because the title bar is the same for all windows.
I have been trying to write a Ruby script that shows the file name of the active cell in the title bar and its tab. I have included the script below.
module UpdateTitle
include RBA
class MainViewObserver < Observer
def signal
version = RBA::Application.instance.version
mw = RBA::Application.instance.main_window
lv = mw.current_view
if lv == nil
# No layout is open
mw.windowTitle = version
else
cv = lv.active_cellview
if cv.ctx_cell == nil
# Created an empty panel
else
cv_fn = cv.filename
if cv.filename == ""
# Created a new layout, not saved yet
else
# Layout with file name is in current tab
mw.windowTitle = "#{cv_fn} - #{version}"
lv.title = "#{cv_fn}"
observer = MainViewObserver::new
mw.add_current_view_observer(observer)
The script works quite well; currently, the file name in the title bar and tab changes when the tab is closed or changed.
I can think of three cases, though, when the file name in the title bar should change without changing the tab.
I was wondering whether there are observers that can detect these events, and how they can be used. I have been trying add_cellview_observer, but have not been able to get it to detect the three cases above. I am new to Ruby, so that may be one of the reasons.
I am using version 0.22.9 on Windows 7.
A workaround for these cases is just to change to a different tab, but any help in solving them would be greatly appreciated.
Many thanks.
Z Lim
Hi zlim,
For someone calling himself "new to Ruby" this is actually quite good :-)
Regarding your request, there are some more event you can register at in the LayoutView class, but there is no event for "save as" currently, so that problem is hard to solve with the observables provided.
It is possible however to solve the problem with a different approach: by registering a QTimer object which periodically (i.e. every 100ms) polls the current title and sets the window title accordingly.
The code below demonstrates the solution. This approach uses Qt signals which provide a somewhat more convenient mechanism to register code with events.
Below is some code that demonstrates how to register an event at a new LayoutView object. It uses the "new_view" event to register a handler when a new view is opened. The code also demonstrates to extend the Observer class with such that it is somewhat more convenient to create event handlers. This scheme does not require to derive a new class and allows to reference variables from outside the block.
But as I mentioned this does not solve your problem. The timer approach is better suited. This code is provided as add-on information.
The timer is a good idea and the script works well.
Thank you!
Z Lim
