Hi Matthias -
Shapes' user properties (key and value - or PROPATTR and PROPVALUE in GDS spec) - can be easily accessed and controlled in klayout GUI - is there any way to access them in Ruby, programmatically?
(I searched the manual, and the Forum - and still have no clue...).
Max
Hi Max,
The respective methods are Shape#set_property to set a property and Shape#property to get a property (or nil, if no property is set). Every property has a value and a key. In GDS, the key is always a number (PROPATTR) and the value is a string. In OASIS, keys and values can be strings or numbers.
thanks a lot!
I guess this feature was not documented in Klayout-0.21.16-2.pdf...
Max
Hi Max,
well, 0.21.16 was not featuring those methods. I'll update the PDF documentation some time, but frankly that's not my top priority. If you want to have an up-to-date documentation, I'd ask you to look for the online doc or the build-in one.
