Not stream-out the empty cells
edited January 2010 in General
Hi.
I have the necessity to stream-out a 'reduced' gds, just 3 layers.
I select the layers I need, I hide all the others and then I set in the save_as mask the 'Layers to save' to 'Visible layers only'. So the gds I stream is ok but I would like to not stream the empty cells and their references. Is it possible?
Thanks, Salvatore D.
  • edited November -1
    Hi Salvatore,
    currently there is no such functionality available. Unfortunately there is little support for deleting cells in Ruby scripts, so there is no simple way to add this functionality with a Ruby script.
    However, it's a very good suggestion. I'll consider that for the next release.
