How to code the intersect function, when 2 polygon cross each other OR have a common edge (inside ou outside) ?
I tried , but it does not work (because .and cannot take both edges and polygons at the same time):
layer1.edges.and(layers2)
Thanks, Best regards,
Laurent
Hi Laurent,
That's right - intersection of edges and polygons are not allowed currently.
But it should be possible to emulate that with
This will leave only those edges of layer1 which are inside layer2 polygons because only those are not coincident (hence are not removed by the "not") with layer2 edges.
But that will not catch the case of layer1 touching layer2. Those touching edges you can detect by
