Hi Matthias -
it appears that if one wants to move the whole layout in klayout using Edit -> Layout -> Move by, the movement vector is defined in terms of dbu units (typically 1 nm), rather than in terms of microns - as implied by the label in the "Move" menu in klayout - can you confirm this?
I am using klayout on Windows 64bit version 0.23.1.
Max
Hi Max,
you're right. Thanks for mentioning that. It should be micron, not database units.
I'll fix that in 0.23.2.
matthias
(for now, I am adding three zeros, to make this feature work correctly).
Max
It's actually fixed - 0.23.2 uses micron units.
Thanks for mentioning this.
