With this you can get the global grid:
http://www.klayout.de/doc/code/class_MainWindow.html#m_grid_micron
Is there a way to SET the global grid, in Ruby script?
Thanks.
Hi David,
yes there is, although not directly:
The set_config method is pretty generic. You can basically set every parameter that is stored in the configuration file (you'll find it under ~/.klayout/klayoutrc on Linux for example). That includes many features like background color or display properties. The second parameter has to be a string, hence the "to_s" method on the grid value (0.1 micron).
The set_config method is also available for LayoutView. That allows configuring views independently from others.
