Hi, Matthias:
I report a bug on the sized function in DRC script. The fucntion sized(value),value should be dbu or micron. I found it's free to use. Here is example:
###########code start #####################
width=[200,250,300]
space=[150,180,200,300]
poly=input("1/0")
tiles(0.1.mm) ## for 100um tiles
tile_border(5.0.um)## for 5um border
threads(4) ##use 4 CPU cores
##calculate space Perato
ss_old=poly
i=0
space.each do |space|
j=i+1
halfsize=space/2 ##for micron? or DBU??
halfsize=halfsize.to_i ## change to integer
## to pick space = 150,180,200,300 spaces groups ##
ss=poly.sized(halfsize).sized(-halfsize)
s=ss.not(ss_old)
layerSave="""S"+space.to_s+"nm (2/"+j.to_s+")""" ## to save layer (name(layer)) "Sxxxnm 2/j"
s.output(layerSave)
puts "space=#{space} nm done; save to #{layerSave}"
i+=1
ss_old=ss
puts "total #{i} space groups"
TotalSpace=i
##calculate width Perato
i=0
ss_old=poly
width.each do |width|
j=i+1
## caculate width as micron unit.
halfsizew=width.to_i/2000.0
halfsizew=halfsizew.to_f ## change to float
##pick width 0.2,0.25,0.3 groups
ss=poly.sized(-halfsizew).sized(halfsizew)
s=ss_old.not(ss)
layerSave=="""w"+width.to_s+"nm (3/"+j.to_s+")""" ## to save layer (name(layer)) "Wxxxnm 3/j"
s.output(layerSave)
puts"Width=#{width} nm done; save to #{layerSave}; halfsize #{halfsizew}um."
ss_old=s
i+=1
puts "Total #{i} width groups"
TotalWidth=i
##return no border
no_borders
flat
### free all memories
s=nil
ss=nil
ss_old=nil
poly=nil
GC.start ##Gabage Collection start
##########code end here###############################
I found that sized can access the 100, 200 DBU unit but also acess 0.18, 0.15 micron unit. Is it bug?
arided
Hi arided,
well, actually the behaviour is intended.
The implementation of "sized" and other functions which accept distance values is such:
So basically, by using to_i, you fool the system :-)
If you explicitly use units, you can avoid these issues. You can specify units also for variables, for example
But, I'd rather prefer the use of units with constants
Beware of the following:
You can work around that by explicitly using ".dbu":
the latter works because ".dbu" actually converts to micron units (hence Float type).
Understood. Thank you!
arided
