Hi!
When using either the Diff or XOR-tool to check for differences in two layouts, the marker database browser only shows and highlights the first 1000 markers per category.
Usually, this is quite sufficient, but I'm sometimes in the unfortunate position, to have more than 1000 differences per layer.
Is there an easy way, to boost this number a couple of magnitudes?
Thank you very much for your time and effort!
Michael Prott
I'm happy now :-)
Hallo,
The reasoning was that typically you would not like to browse through more than 1000 errors ... :-)
But you can easily choose a million or more. But if you ask for a very high number of markers, you should consider using a layout for output and produce a geometry layer. That is far more efficient.
