Hi, Matthias:
The sized function is flat application. It calculates with more precession but waste huge memories. I am try to reduce memory usage. So I need to call the "edit/layer/size" function with "semi hierachical" option. How could I call that function?
arided
Hi Arided,
there are many sizing functions - DRC, user interface, scripts ... which are you talking about? Can you be more specific on what you are planning?
And yes, the basic versions are flat. This is to avoid problems with touching instances on negative sizing for example. A precise and efficient hierarchical implementation is somewhat beyond the scope of an open source tool.
