Open layout
edited March 2014 in KLayout Support
Hi Matthias-
When opening new layout, sometimes i get the dialog asking me if I want to open in the same tab \ differnt tab etc.
Other times it will put it immediately in a new tab.
For other user I see it never fires the dialog and opens instead of teh existing one.
Is there a way to always have the dialog starting when opening new layout?
Thanks much, Itamar
  • edited November -1
    Hi Itamar,
    I'm confused. "File/Open" should always replace the current layout with the new one. "File/Open in new panel" should add a new tab. Dragging and dropping a layout however will ask you whether to replace the layout or open a new tab.
    Are you using the same version than the other users?
    Yes. My bad. You may delete this discussion
