you can configure all of that in the Setup menu. The configuration is stored in a file called klayoutrc in KLayouts home folder (on Windows typically in a folder called "KLayout" in your home directory, on Linux in ~/.klayout). You can copy away that file - for example in "someplace/myconfig" and run KLayout to use that configuration plus edit mode:
klayout -e -c someplace/myconfig
If you add the -t option, the configuration file will not be updated when the program is closed. That way, settings made in the setup dialog will become temporary. Please see "klayout -h" for a list of all options available.
You can make KLayout to use a specific configuration initially (for example, if you're are maintainer of a company-wide installation). To achieve this, copy the "klayoutrc" file to the place where the klayout binary is located. If KLayout finds a file with that name in it's installation path, it will initialize itself with these settings on the first call.
You can script that settings too, but I feel that the configuration file approach is easier to use.
But the value is some binary string that Qt uses internally to store the window state. If you close KLayout in full-screen mode, it will write the corresponding state and geometry you can copy that values over to your default setup.
You tyanata,
Yes I am maintainer of a company-wide installation, I already found the approach with "klayoutrc" file.
I already made "klayoutrc" file to set background and start in editor mode:
<config>
<background-color>#000000</background-color>
<edit-mode>true</edit-mode>
</config>
But could not find how to predefine it to start in Full screen and Display = Full Hierarchy.
tyanata
Hi Tyanata,
the window geometry including full-screen mode is encoded in
will select full hierarchy on loading.
The approach is working.
tyanata
