The folks at RH tell me Qt version 3.3 is the supported version RHEL 5.3 on 32bit x86 systems. Will Klayout work if built with it, or must I update Qt?
KLayout requires at least Qt 4. Usually there is a Qt 4 package you can install in parallel to Qt 3.
I would recommend 4.5.x, but any Version >=4.1.x should do. You can also try 4.6.x. It should work, but I don't have much personal experience with that one.
I found the updates:
Application>add/remove software> goes into package manager, check the following boxes and apply:
qt4-4.2.1-1.i386
qt4-devel-4.2.1.1.i386
qt4-doc-4.2.1.1.i386
Hi Rosario,
qt4-4.2.1-1.i386
thank you
