You a note of caution: when you specify a Windows path with backslash characters ("\"), make sure you use a double backslash since a single one will specify special characters such as the newline character ("\n"). For example:
source("C:\\test.oas")
I don't see that in your above example, so I wonder what is wrong.
that should work, doesn't it? What is happening?
