I have some gds file which contains some rectangle with arc at its corners. When the gds file was open by Klayout, it was automatically deccompsed to many small trapezoid. Though can be merged by Tools/layer/Merge function of Klayout, is there any options to keep the original polygon structure not to be convert to trapezoid after open the file in Klayout ?
Hi Sunny,
that is pretty strange. KLayout will never modify a Polygon on reading. So it must have been decomposed already when you created the file.
How was that file created?
By the way, Is there any script or tools to do merge for all layers in the layout instead of do it layer by layer at tools/layer/merge function ?
Hi Sunny,
I was guessing so. But I'm not aware that Cadence does not decomposition. Maybe the maximum number of polygons is set to a very small value.
Regarding the merging: you can do that with a DRC script. The basic scheme is
The script can be written such that it will iterate over all layers automatically:
Disclaimer: I have observed some instability when running that script twice. I'll have to look at that more closely.
Please also note, that merging will flatten the layout and remove all text objects since they don't contribute to polygons.
