Hey there,
Hope you are doing well. I am receiving some execution errors while trying to generate *.lyp file.
What I do is
1. File > Import Cadence techfile
2. Select the .tf provided by the foundry for Cadence tool
3. Select the Display Resource file
After that is done I receive an execution error, I have tried to modify the techfile or the display or try with different technologies and the result is the same
Do you know what can be causing the issue?
Thanks for your help
KLayout automatically select the files in klayout installation directory, especially the display.drf
I recommend to change all the extensions of your previous technology(ies) so that KLayout can find them.
Laurent
Hi mfidalgo,
I can just guess. Is there any error messages given? Knowing the cause will be very helpful to debug the problem.
In general you cannot import any kind of Cadence techfiles. Some are written in a way to contain Skill code which the script cannot execute. The safest way is to export the techfile in Cadence and use the exported one. This one is free of skill code. Please also make sure you use the most recent version of the script.
Mathias,
Is there a particular email where I can send you the attachment of the error I found? It seems to be a Ruby error but I would liked to attach this for better understanding of my problem
Regards and thanks in advance
Hi mfidalgo,
please send a mail to the adress mentioned on the Contacts page. If possible please include the techfile and display.drf.
