Hi there,
I'm using your program more or less every day since last week and I figured out some problems, maybe one of you has an answer.
- Is it a general problem, that I can't copy/paste from one open .gds-file into another?
- If I have a structure, say a circle, is it somehow possible to repeat this structure in x&y direction to create an array? right now I solve this problem with copy/paste the particular structure over and over again, which is a stupid job to do when building big structures.
- And when I tried to use the function "rounding corners" I have the problem, that I can't use it, when my structures get to small (say 1µm) whereby I'm still able to do the same job by creating a polygon. Is there a way to still use the function "round corners" for small structures as well?
Would be great if one had an idea, makes life somewhat easier...
Best regards
Julian
Hi Julian,
Hopefully that is useful.
