Steps to recreate the problem: (KL 0.23.3 on Win 7.)
- Draw a shape like a box or wire. Select it > 'q' > User Properties button > Add.
- Add the property 'SKIP' => #1. Add another property 'R' => #50. Look at the properties, they both look fine (#1 and #50 are numbers).
- Click OK to go back to the shape properties dialog box, and then click the User Properties button again to view the properties. R is preserved as #50, but 'SKIP' has turned in to '1' (i.e. not a number).
Note there is a little further strange behavior, for example:
- If I next rename 'SKIP' to 'S' or 'SK' or 'SKI' (and change the value back to #1) then try going into and out of the User Properties dialog, then the #1 is preserved as a number. But as soon as I put 'SKIP' then it converts it to a string after step 3 above.
- Furthermore if instead of 'R' => #50 in step 2, I put 'R' => #100, I do not observe the behavior (both numbers are then preserved).
Let me know if you can recreate it! I wonder if this is some limitation to how OAS stores properties?
David
Hi David,
After some tries I can reproduce the problem. It arises if you have used the key/value combination in other places too.
I'll try to fix that in the next minor release. Thanks for reporting that.
