Unable to insert DPolygon into layout
edited March 2015 in General
Hy all,
I just wanted to build a DPolygon out of several DPoints and insert it into my layout. The code looks something like this:
p1=RBA::DPoint.new(x1,y1)
p2=RBA::DPoint.new(x2,y2)
points=[p1,p2,...]
element=RBA::DPolygon::new(points)
cell.shape(layer).insert(element)
The error message says: "No overload with matching arguments in Shapes::insert"
With the non-double methods "Point" and "Polygon" everything works fine.
Has anyone an idea what I'm wrong?
Thanks for your help!
  • edited 6:05AM
    Same problem and answer here: http://klayout.de/forum/comments.php?DiscussionID=584&page=1#Item_4
    Basically, there is no insert method that takes that argument. Use Point and Polygon, and divide all x and y coords by layout.dbu.
  • edited 6:05AM
    Thank you, now it is working. I have achieved it with the "from_dpoly" function as suggested in the link you gave me.
    points=[p1,p2,...]
    dbu=layout.dbu
    element=RBA::Polygon::from_dpoly(element*(1.0/dbu))
  • edited 6:05AM
    A brief comment of mine: I'd like to discourage the use of the D-shape types because they inherit the numerical issues involved with floating-point values. Plus you should be aware of potential overflow issues when transforming the double types to integer types.
    If possible I'd use the integer types and work with dimensions expressed in terms if database units.
  • I again have the same issue with that script to copy a box from 1 layer to another layer :
      mw = app.main_window
      lv = mw.current_view
      if lv == nil
      raise "No view selected"
      cv = lv.active_cellview
      if !cv.is_valid?
      raise "No cell or no layout found"
      cdbu = cv.layout.dbu
      sel_layers = lv.selected_layers
      if !sel_layers || sel_layers.size == 0
      raise "No layer(s) selected"
      layer_info = LayerInfo.new(15,0)
      layer_index = lv.layer(layer_info)
      cv.layout.each_cell do |cell|
        sel_layers.each do |l|
          li = l.current.layer_index
          if cv.layout.is_valid_layer?(li)
               cell.shapes(li).each do |s|
                  if s.is_box?
                    p1 = s.box_p1
                    p2 = s.box_p2
                      box = RBA::Box.new(p1.x,p1.y,p2.x,p2.y)
              cell.shapes(layer_index).insert(box)
    I don't know where is my mistake ?
    Laurent
  • Hi Laurent,
    These lines
    need to be written as:
      layer_info = RBA::LayerInfo.new(15,0)
      layer_index = cv.layout.layer(layer_info)
    LayoutInfo needs to be qualified with the RBA namespace and "layer" is a method of the Layout object which you get from "cv.layout" as there can be multiple layouts in one view.
    BTW: the short version is simply:
      layer_index = cv.layout.layer(15, 0)
