Hi:
I am using KLAYOUT for mask review, and frequently do a screen shot of a particular location to show to someone else. I'd like to be able to have the mask coordinates including in the screen shot "closer" instead of at the bottom right corner of the window. I frequently just snip part of the window.
Is there any way to have the mouse cursor set up to show the location coordinates it's pointing at?
Or is there some way to reposition the x,y coordinates into a separate, standalone little window?
Thanks. Great work
jmhutchi,
Nice last name
Perhaps we have the same.
Matthias may tell you otherwise, but here is my take.
What you ask is possible via "Plugin" class of the API. But it's very tricky.
Perhaps instead you have a script that does the following. You manually place a text ("Text" button in toolbar) wherever you want the coords to show up. Then select it. Then you can write a script to set the text text to the correct coordinates when you press a hotkey. Here's a simple example -- this can be expanded. So, put this as a new .lym file in Macro Editor, and click the orange 'Properties' button to assign a shortcut key.
what I do in these cases is to use rulers for marking those positions.
Rulers can be configured in various ways and you can defined new ruler classes. You can use that feature to set up a "pointer" style ruler which shows the target location. Here is a recipe:
Close the ruler setup dialog with "Ok". You now have a choice of two rulers in the toolbar: the normal one and the new "Pointer". Choose the pointer and click on your desired target location and drag the pointer to place the end of the arrow plus the label. After taking the screenshot you can remove the ruler with Ctrl+K and place new ones.
Thank you for your suggestions.
The "Pointer" ruler type is really useful.
Sorry for not writing sooner.
