I am new to Ruby scripting and I am trying to rename all cells in input gds by a prefix "hello_".
I am able to do it by inserting a menu item as shown below:
File klayout_test.rbm :
self.title = title
self.shortcut = shortcut
@action = action
def triggered
string = "hello_*"
mw = app.main_window
view = mw.current_view
layout = view.cellview(view.active_cellview_index).layout
layout.each_cell do |cell|
cell_name = layout.cell_name(cell.cell_index)
new_cell_name = string.gsub(/#/, cell.cell_index.to_s).gsub(/\*/, cell_name)
if cell_name != new_cell_name
layout.rename_cell(cell.cell_index, new_cell_name)
opt = RBA::SaveLayoutOptions.new
view.save_as(0, # cell index, for some reason it needs to be "0"
"output.gds", # file name
0, # do not gzip output
opt)
private
@action
$rename_cells_handler = MenuAction.new( "Rename Cells", "" )
menu = mw.menu
menu.insert_separator("tools_menu.end", "sep_rename_cells")
menu.insert_item("tools_menu.end", "rename_cells", $rename_cells_handler)
When I read the above file in klayout by :
klayout input.gds -klayout_test.rbm
klayout window opens up with "Rename Cells" option in tools. On selecting the option in GUI, all cells are renamed by a prefix "hello_" and the resulatant gds is saved as output.gds. However I want to use it in non GUI mode. For that I wanted to trigger the above procedure through command line. If I use the following command :
$rename_cells_handler.triggered
I get an error saying "Undefined method `active_cellview_index' for nil:NilClass"
Please help me out on this.
when you execute the script directly when loading it, you will not find a layout since that is loaded after the script.
But there is a far easier solution: you can instantiate a layout without user interface and directly manipulate the content. This is your sample written that way:
You can save this script to a file, for example "test.rb" and run it this way:
"-b" will run KLayout in batch mode which switches off several features which you don't require in this script. "-rd x=y" will define a global variable $x with a value "y", so you can access input and output as "$input" and "$output" in the script.
