LayoutView.reload_layout clears the technology
edited May 2015 in Ruby Scripting
I'm having a small problem with LayoutView.reload_layout. It seems to make the current cell view's technology blank but not nil. I'm using KLayout 0.24-python-eval on 64-bit Windows 7.
I notice this problem with the following steps:
<open a GDS>
mw = RBA::Application.instance.main_window
lv = mw.current_view
cv = lv.active_cellview
cv.technology # This returns the name of the current technology
lv.reload_layout(0)
cv.technology # This is now blank
I changed the technology with the technology button (the T in a circle) and while the layer definitions changed, the label in the bottom left-hand corner did not change.
Everything behaves properly once I open a new panel and return to the original, but I cannot do this in a script. I can write my script to deal with blank technologies, but I feel that reload_layout should not clear the cell view's technology.
Is there any time when the technology is intentionally blank?
Also, when would reload_layout take a non-zero cell view index?
ETA: I found that if I re-read mw from RBA::Application.instance.main_window, I can get the technology from the cell view. I still see that the label in the bottom left-hand corner is not changing, though.
Thanks and regards,
Z Lim
  • edited November -1
    Hi zlim,
    thanks for mentioning this issue. That's a bug. I'm afraid the only workaround until the real fix will be to close and re-open the layout or to store and restore the technology after the reload. But the problem also persists when reloading from the menu. Hence it needs to be fixed.
