I install a new server with KLayout and when i launch this application all window is grey.
I can't see any menu or any information, but if i test a shortcut (example CTRL+O for open a Layout File, this window work, but after if i select a layout file the main window is always grey.
do you have any idea what might block my display?
Thank you for your help
Hi Cyrille,
maybe GTK style is broken. Could you try using a different style, i.e.
If that still doesn't work, I suspect a problem with the Qt installation. Do the normal Qt tools (i.e "designer") work?
