undo stack
edited June 2015 in Ruby Scripting
Is there any documentation on the undo stack?
I am looking for information on how to trigger undo/redo for a transaction.
  • edited June 2015
    You might be interested in the Manager class which is documented here.
    Regards, Chris
  • edited November -1
    that helps. Thanks, Chris!
  • edited June 2015
    Hi Chris,
    thanks very much for the comments!
    I just like to add that usually you won't need the manager object. The LayoutView#commit and LayoutView#transaction methods are usually sufficient:
    # Begins the transaction (undo/redo support)
    view.transaction("Description of your function")
    begin
      # your code goes here and will be undo/redo-tracked
    ensure
      # Always commit (also in case of an exception)
      view.commit
