Hi Do we have any scripts which converts OASIS to understandable text format ?
I want to see and identify individual polygons in OASIS so that I can add/modify details in it.
Any input is highly appreciated.
The easiest option would be to simply Save As... GDS text. As GDS isn't as rich as OASIS, the file might be missing some information that exists within OASIS, but depending on your specific use case, it might be enough.
If you want to have a deep look into the OASIS internals, you can use the OASIS dump tool: http://www.klayout.de/dump_oasis.html. But that is just one-way and you'll see all these nitty gritty bits you are probably not interested in.
Hi!
Regards, Chris
Hi Chris,
thanks for that comment.
