I would like to run a script for layer processing with the layer_proc.rbm through the command line in the non-GUI mode using the -zz option. Is this possible and what is the syntax?
Since version 0.23 there is a much more powerful framework integrated into KLayout (the DRC framework). The functionality is pretty similar, so it should be possible to rewrite layer_proc scripts to DRC scripts. For a description of DRC scripts see http://klayout.de/doc/manual/index.html.
You can run DRC scripts with extension ".drc" from the command line using to notation:
klayout -b -r myscript.drc
(-b is equivalent to -zz, but disables other options too).
Here is a simple example for a DRC script:
# specifies input (file, top cell)
source("input.gds", "TOP")
# specifies output
target("out.gds")
# computes intersection of layer 2 and 3 and outputs the results to layer 100
res = input(2, 0) & input(3, 0)
res.output(100, 0)
Hi WaveGuy,
