To get one selected layer we can do
cl = lv.current_layer
if cl.is_null? || cl.current.layer_index < 0
raise "Please select exactly one layer"
input_layer = cl.current.layer_index
How do we instead get an array of all the layer indices that are selected in the layer list?
Let's say we select three layers in the layers list. Then there are three LayerPropertiesIterators that are returned from LayoutView#selected_layers. Why three LayerPropertiesIterators, why not three LayerInfo objects or three layer_indices?
I tried to use the resultant LayerPropertiesIterators like iterators, but unfortunately this:
cl = lv.selected_layers
if cl.length == 0
raise "Please select at least one layer"
input_layers = []
cl.each { |c|
while !c.at_end?
input_layers << c.current.layer_index
c.next
p "input_layers = #{input_layers}"
...gives the result
input_layers = [0,1,2,1,2,2]
(Notice the repeats.)
David
OK I see now that LayerPropertiesIterator is appropriate, because I forgot that layers in the layer tree can have complicated hierarchical grouping structure, so this handles the case where the user selects the parent group for instance.
So to just get the selected layers, this seems to work:
...gives the result
yes, that's exactly, how it is meant :-)
Please note that in general the selection can contain layers from different layouts if there is more than one layout loaded into the view. You'll find different values of
c.current.cellview
then, so you should check whether that value is the expected one (I'd suggest matching againstlv.active_cellview_index
).There may also be nodes which don't have a valid
layer_index
(for example group nodes), so you should skip values less than zero.And finally, different layer properties nodes may refer to the same layout layer (maybe with different transformations or styles), hence you could add a final
input_layers = input_layers.uniq
.Or in a single line:
