First thanks again for your amazing work !
I noticed that when i am saving a gds from Klayout, i am losing all the layer properties when i load it (color, name, stipple, ...). Is that a limitation of the gds format ? Is there any workaround ?
Thanks a lot
Simon
Next time, you can load it by selecting File>Load Layer Properties.
You can also load a default layer properties file automatically every time by selecting File>Setup>Application>Layer Properties. Check Use default layer properties file checkbox. Select the default layer properties file by clicking on ... button.
When specifying a default .lyp file, is there a way to "wildcard" the source layer so that the settings will be applied to all layers?
Scott
edit: found this post which solves my problem
https://www.klayout.de/forum/discussion/330/load-layer-properties-file-in-or-mode
